what the?!
Ok, first off, I would like to say thanks for letting me be part of this forum. There looks to be a great amount of knowledge anand even greater people...
Now on to the issue at hand....
Does everyone's monte carlo just turn to crap after 150k miles? I had a window regulator, several fuses and many other issues just pop up within the last 5k miles and I'm about ready to junk this 2003 Monte carlo.
Just recently, the transmission won't shift. I can put the pedal to the floor and only turn 2500 rpms regardless of the speed I'm already going. Climbing in speed takes for-ever! New fluids and all...Won't even try to change lanes and god forbid I have to get on the freeway.
Anyone know a cheap place to go get a used trans? I'm just about done with this car...
Sorry to hear about the problems you are having with you Monte
Anyway, welcome to the forum. You will find a lot of information and great people here.
I am not a big one for giving much technical support as I barely know what I am doing...LOL I am sure that someone will respond to your post who can give you more information on where to start.
Sometimes you get lucky?
First did you test drive it?
I mean really run it through its paces?
I run them out to the highway and manual shift it and then from a stand still and let the automatic do it's thing.
I had one guy chew me out for that? I said the sticker says as is no warranty? How am I gonna know what its like?
Maybe have a technician look at it also before the purchase?
Can you check the Trans. fluid level or is it a sealed unit?
I have an 06 Pontiac Torrent and you can't check it?
I asked the dealer where it was and they indicated it was sealed.
So if you check the trans level and it is low of the juice is brown it probably has never been changed.
You might try some Lucas Oil trans. additive and it may work better.
Good luck with your project, I am hoping for a cheap fix.
It can sometimes be a skill/art/craft eying up used cars. You have to get an idea on if it was maintained and how it was driven. Even after that, you still sometimes end up paying for the sins of the previous owner(s).
Any car driven hard and improperly maintained, along with other forms of abuse to the car will almost always fall short in reliability. There is also another percentage of just plain bad luck.
Has anyone scanned the computer for current or past codes that have popped up? That can sometimes save some pounding your head into a wall.
Below is a link to a thread of various maintenance things to look at when the car rolls 100K. It's possible any one or a combination of them is causing you grief.
https://montecarloforum.com/forum/fw...0-miles-46078/ <---- Click here
Also, have you had a trusted mechanic look at it? I don't mean a certified mechanic, or a shop you like to go to. I mean a guy that you believe knows his stuff and usually steers you on the right path with your car maintenance? The reason I ask, some people shop around and get opinions from different mechanics/shops. It helps from the beginning if you have someone you trust when you talk to them from the beginning.
Hopefully you can get your Monte issues resolved quickly, easily and cheaply.
Welcome to the forum:
Sorry to hear your having issues with your Monte..
As mentioned previous.. Theres lots of great members and info here.
Were here to help.
As I see a cpl of our professional members have given you a few ideas as well as a link to some things to help you along the way..
My guess in regards to RPM issues could be a possible clogged catalytic converter...
But also..
Depending on the color(should be bright red)/smell (not burnt)of the transmission fluid a filter fluid change maybe in order.
Please keep us posted on your progress/resolve as the solution may also help others..
Thanks for joining the MCF Family!
Were here to help.
But also..
