water in trunk
Old May 3, 2010 | 04:23 PM
Overdose666's Avatar
Originally Posted by captaindamnit
well now that the weather has nicend up I did some looking... It turns out it is coming in from a loose weld on the trunk... hard to explain where, but Ill get pics up today. AND it turns out there are a couple inches of standing water hidden away in the trunk.. Ill post pics of those too.. Im going to drill a little hole to drain it. You guys might want to check urs out too.
well im not sure if its the same with all 6th gens, but my 03 has some rubber plugs below the spare that u can remove to drain the water
Old May 15, 2010 | 01:35 AM
Kudz_SS's Avatar
Ive had the same problem with my 02 MC SS. Water was leaking in from a faulty seam behind and just below the passenger side taillight. Its hard to see the seam. Water was standing inside the well pocked behind the tire in the quarter panel. I re-caulked the seam and the leak went away.
Old May 19, 2010 | 12:57 PM
captaindamnit's Avatar
Sorry for not updating on this but here is some news. I got to looking and couldn't find where the water was coming in, but I found where it was staying.
Here are some pictures that I hope will help explain.Under both sides of the trunk there are these trough things that in mine are collecting water... I just pulled out the plugs that are on the side that points out of the car.. a little tricky to get to.Pull Back the carpet and there was a GOOD amount of water in there.. I'm Hoping that it will be taken care of now.
Maybe you guys should check to see if you have the same problem. I don't think the previous owner EVER looked there. It was nasty!
BethinIN
Oct 2, 2012 06:50 PM
monte carlo 3831
Nov 21, 2011 10:01 AM
96chevyridinheavy
Mar 17, 2011 07:53 PM
monte07
Jul 5, 2010 03:57 PM
Brooke
Oct 17, 2007 04:35 PM
