2006 Monte, water in trunk/spare tire area...
Old Nov 19, 2011 | 10:13 PM
Default 2006 Monte, water in trunk/spare tire area...
Has anyone here had a leak in their trunk? I do, not sure why, maybe from sitting to long in my driveway? I haven't been driving my car that much lately and it sits in the driveway on a slight upward angle and tonight I noticed some dampness on the carpet. I took out the spare tire cover and noticed about half of the spare tire space filled with water I have in the past noticed dampness on the trunk carpet but not that bad until now. I'm just wondering if anyone had the same issues. It must not be that big of a problem because there are two drain plugs back there! Here are a couple/few pics.......
and the trusty old butterknife to open the plugs...............
Old Nov 19, 2011 | 10:23 PM
wow thats quite alot of water no idea where its coming from?
Old Nov 19, 2011 | 10:27 PM
No idea, most likely the trunk seal is leaking water or maybe there is water leaking from under the spoiler into the trunk?
Check ur spoiler bolts, might have bad seals around the holes thats where id start
Old Nov 20, 2011 | 02:54 AM
mousehousemoparman's Avatar
Get a helper to lock you in the trunk with a good light. Have the helper run the garden hose over the back of the car. Don't dismiss the seal around the back window and quarter windows. Also check to see if you have moisture under the back seat.
Old Nov 20, 2011 | 09:57 AM
Jomao_o's Avatar
Wow Chris, that sucks.
I hope you get this figured out and isn't a costly repair.
Best wishes bud.
Old Nov 20, 2011 | 01:25 PM
That totally sucks Chris - I have never really heard of a newer car getting water in the trunk - very common with the classic A body cars.
Old Nov 20, 2011 | 01:51 PM
Ricks 2006 SS's Avatar
Default water
Hey Chris: If you do what Gregg says to do. Make sure he lets you back out ...............
Old Nov 20, 2011 | 08:45 PM
04chevyboy's Avatar
i had this happen one day after it poored,only the water was in my passenger side floor
Old Nov 20, 2011 | 08:59 PM
Rick you make me laugh. I forgot to mention to check the tail light seals.
