water pump leaking
ls ss? if i'm not mystaken i have done one on both the 3.4 and 3.8 has to be the easiest on i've done on a newer car check out the how too section there may be a wright up
No the the 3.1-3.8 have timing chains you don't need to go that far in, if i'm not mystaken the 3.4 is the easiest, just undo the belt shild belt, pully, pull off the bolts for the pump pull it out then clean and pop in the new one in
The "timing" belt/chain is NOT part of the pump. You need to remove the serpentene belt (this can be done with a rachet with a pipe over it or breaker bar if you don't have tensioner lift bar). Once you can remove the 4 bolts holding the pulley on (easy to do if you have an air rachet), I believe there are 7 small bolts holding the pump in. Remove those bolts and the pump falls right out (may need to tap it with a block of wood and a hammer to break the gasket seal). Clean up the gasket surface on the engine and put it back together.
First time I ever did one, I think it took 30 minutes. Piece of CAKE, one of the quickest and easiest repairs on a 3100/3400.
LonelyStoner
07-22-2010 02:07 AM
