water pump leaking
Old Feb 23, 2011 | 09:52 AM
goingforgold's Avatar
Default water pump leaking
Can anyone tell me the process for changeing the water pump on my 2002 monte? Can I do this myself or do I need to take it to the dealer for repairs?
Old Feb 23, 2011 | 10:17 AM
Budsjlm's Avatar
ls ss? if i'm not mystaken i have done one on both the 3.4 and 3.8 has to be the easiest on i've done on a newer car check out the how too section there may be a wright up
Old Feb 23, 2011 | 10:23 AM
Budsjlm's Avatar
Old Feb 23, 2011 | 10:26 AM
Budsjlm's Avatar
Old Feb 23, 2011 | 10:27 AM
sorry I've got the 3.4. Does the timing belt run on the water pump?
Old Feb 23, 2011 | 10:37 AM
Budsjlm's Avatar
No the the 3.1-3.8 have timing chains you don't need to go that far in, if i'm not mystaken the 3.4 is the easiest, just undo the belt shild belt, pully, pull off the bolts for the pump pull it out then clean and pop in the new one in
Water pump on both the 3.4 and 3.8 are easy (I'm a little more versed on the 3.4 as it's the same setup as the 3100's I've worked on). Hardest part of the job is getting the 4 bolts out that hold the pulley onto the pump.
The "timing" belt/chain is NOT part of the pump. You need to remove the serpentene belt (this can be done with a rachet with a pipe over it or breaker bar if you don't have tensioner lift bar). Once you can remove the 4 bolts holding the pulley on (easy to do if you have an air rachet), I believe there are 7 small bolts holding the pump in. Remove those bolts and the pump falls right out (may need to tap it with a block of wood and a hammer to break the gasket seal). Clean up the gasket surface on the engine and put it back together.
First time I ever did one, I think it took 30 minutes. Piece of CAKE, one of the quickest and easiest repairs on a 3100/3400.
Old Feb 23, 2011 | 10:51 AM
Thanks all the info it really helped.
75Fire
Aug 20, 2011 06:01 PM
LonelyStoner
Jul 22, 2010 02:07 AM
teamfbody
May 4, 2010 10:49 AM
greatness107
Dec 28, 2007 10:30 PM
Brooke
Oct 17, 2007 04:35 PM
