Vibrations felt while driving
Old Apr 21, 2008 | 11:41 AM
rage772's Avatar
Default Vibrations felt while driving
My 86' Monte Carlo SS has been showing a strange problem. Everytime I reach speeds of 55mph+ the whole vehicle starts vibrating. The vibrations get worse as speed increases but stops DURING acceleration. When I left off from accelerating the vibrations come on again until my speeds drop below 55mph again. I just got new tires, and had them balanced. The problem is still here though. Any ideas what could be causing this? Thanks
Forrest
Old Apr 21, 2008 | 01:20 PM
rysZ34's Avatar
Default RE: Vibrations felt while driving
Are you sure they balanced them correctly or as closely as they could? Other than that, I'm not sure what it could be....Check to see if your tires are cupped at all or if there are any wires showing.
Old Apr 21, 2008 | 01:50 PM
GrandPaDave's Avatar
Have your tires rebalanced.
Old Apr 21, 2008 | 03:25 PM
88ss408's Avatar
and check the drive shaft it could be off ballance or even bent
Old Apr 21, 2008 | 03:43 PM
Sir Monte's Avatar
You might want to check the U-JOINTS.
Old Apr 24, 2008 | 02:45 PM
1WX27's Avatar
bad U joints would show with acceleration, and at low speeds as well...would be more rpm related than speed. I would definately suspect the tires or rims, if that doesn't help check the alignment.
testcase448
Jun 2, 2014 09:13 PM
l0gitech87
Sep 25, 2010 06:45 PM
l0gitech87
Aug 10, 2010 08:10 PM
vipermann114
May 2, 2007 12:08 AM
rj
Mar 11, 2007 01:21 AM
