6th Gen ('00-'05): Viabration in axle?
Old 09-01-2014, 05:53 AM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
Yes the axles I have replaced in my experience usually make a pop or clunking when turning one direction or another. And/ or the cv boot is toasted.
The OP asked if was overkill and prob is to change all. But if changing the hub already you are already 99% there , might as well pull the axle out of the other end and replace it.
He's got a leaking boot any how. Makes more sense to me to replace the axle than just try to change the boot
Old 09-09-2014, 11:35 PM
if the needle bearings in the cv shaft are damaged or missing, it vey well could cause a vibration under throttle. I just replaced both my axles for the same problem. When I pulled the pass side axle, the needle bearings were gone in 2 of the rollers.
Old 09-10-2014, 09:37 AM
GTHSS's Avatar
Thanks flossinon24s. That's good to know.
allan
03-17-2010 09:17 PM
MonteDriver
03-10-2010 07:15 PM
NICK700R
07-25-2008 02:58 PM
reswob
05-20-2006 02:53 PM
01whitess
10-07-2005 08:22 PM
Quick Reply: 6th Gen ('00-'05): Viabration in axle?
