Front Drive axle replacement
Old Mar 10, 2010 | 03:43 PM
MonteDriver's Avatar
Default Front Drive axle replacement
Jill's upcoming maintenance, I'll be doing it in my garage.
Drive axles:
I already have the axles, 36mm socket, maintenance book(for any issues that may come up), jack, jack stands, breaker bar, air compressor and tools, hammer, bigger hammer.
Thermostat:
Thermostat, gasket, coolant, drain pan
Oil Change:
Drain pan, oil, oil filter,
Anything you can think of that i am missing, I have all the sockets and such but its been abit since i turned a wrench and trying to save the money on changing Jill's axles.
She is getting a axle change due to a woble in the front end, and greese on the passenger side around the axle.
Also I will be doing a how to post on this with pictures so anything specific i should detail for you let me know, want it to be as in depth as possible
FYI Jill is a 2003 SS (Jeff Gordon edition)
Old Mar 10, 2010 | 07:15 PM
Sliver's Avatar
I've done my axles as well. It sounds as though you got all your stuff together and you have done all your research. My only suggestion...Beer! Of course not too much otherwise wobbling will ensue!
Good Luck!
MonteDriver
FWD Tech Guides '95-'07
16
Sep 29, 2019 01:30 PM
kcmarkviii
Oct 7, 2013 08:44 PM
JC Colon
Aug 22, 2013 08:09 AM
jasonsmith
Feb 15, 2012 08:11 PM
reswob
May 20, 2006 02:53 PM
