Vehicle computer errors
Old Mar 24, 2020 | 11:00 AM
Alexander McKlemurry's Avatar
Default Vehicle computer errors
Recently i had issues with my Monte Carlo. We found that the temperature sensor was unplugged and we plugged it up to find out. After that, it went downhill. it begin misfiring, it is loading up fuel and now it won't even crank unless the sensor is in it. everything is telling me that this is a computer issues but i don't have the mechanics knowledge or experience to really make a solid decision. If anyone has any ideas on how to fix this or at least get it running and on the road, let me know
Old Mar 25, 2020 | 10:42 AM
nitehawkjcb's Avatar
Check the car for engine codes
Old Mar 25, 2020 | 01:25 PM
already did that. Cylinder misfire
Old Mar 25, 2020 | 02:20 PM
IMO I think it's unlikely the computer itself is bad. It's not impossible, but that's probably item 10 on the list for a cylinder misfire.
TBH, I think you're going to have to take it to a mechanic. If you've got no way to read the sensors and dont have the mechanical knowledge to troubleshoot, then its going to be tough to work through. We dont have near enough info to help at the moment.
Old Mar 25, 2020 | 06:00 PM
Steelbizkit's Avatar
This is true. Could be anything from low compression to simple spark plug.
not to mention misfire code could be limited to 1 cyl or random multiple or misfire on startup(1st 1000 revolutions). Which is way code read would be first stop to see where to start looking.
superss
Apr 14, 2014 08:24 PM
JustKat
Feb 11, 2014 10:35 PM
Bizzyyall
Apr 25, 2013 10:02 PM
pearlring
Mar 19, 2013 04:42 PM
robertbob51
Nov 10, 2009 12:23 PM
