2001 SS ocassionally won't start/stalls while driving
Old Mar 18, 2013 | 06:00 PM
pearlring's Avatar
Default 2001 SS ocassionally won't start/stalls while driving
No check engine light comes on and no code. My mechanic changed O2 sensor, it worked fine for 3 days and and had the same issues.
Old Mar 18, 2013 | 06:44 PM
aussiek2000's Avatar
Oxygen sensor WILL NOT cause no start or a stall. What scan tool is he using? May be codes, just none a cheap tool can pull. My bet would be on a crank sensor. That's assuming you have fuel pressure.
Old Mar 18, 2013 | 07:08 PM
nitehawkjcb's Avatar
I agree, crank sensor is likely. I've seen it be fuel pressure related, ignition related, and MAF related.
Old Mar 18, 2013 | 07:45 PM
pearlring's Avatar
Nitehawk and Aussie, I apologize. The crank sensor was replaced also.
Old Mar 18, 2013 | 10:28 PM
Unplug the MAF when it happens. See if it starts. You could try cleaning your MAF. Check the ground on the ICM harness (It is on one of the studs underneath the ICM bracket). Failing ICM will do this also. Check the fuel pressure.
Bring the car to Autozone, they will scan it and tell you the codes, if there are any stored.
Old Mar 19, 2013 | 04:42 PM
Where is the part from?
Stingroo
Jul 5, 2015 09:14 AM
pearlring
Mar 18, 2013 06:04 PM
litaf201
Jul 26, 2012 10:08 AM
monte2001carlo
Jan 12, 2011 05:17 AM
ChevRev34
Feb 24, 2008 01:10 PM
