Upper radiator hose collapses
Old Jul 22, 2007 | 09:18 PM
tophhckevin's Avatar
Default Upper radiator hose collapses
I have a '97 MC with a 3.4L. I noticed when I bought it with 94K miles that when I was driving, the temperature would go up, idle and it would go down. It has a new water pump, thermostat and hoses. Upon further inspection I finally found the problem. The upper radiator hose collapses when I open up the throttle. Only does it when you give it throttle. Can't figure it out. Any one have/had this problem?
Old Jul 23, 2007 | 06:59 PM
RocknSS04's Avatar
Default RE: Upper radiator hose collapses
Sounds to me like an air bubble in the system. Maybe a clogged radiator. Try bleeding the system at the bleeder valve on the thermostst housing. Might need a new hose if it's real soft. It shouldn't be spongy.
http://www.cardomain.com/ride/2319272
Old Jul 23, 2007 | 09:06 PM
mickey's Avatar
also i know a great fix for this.
the same thing i want to do on mine to just make it more reliabel.
FLEX HOSES!!! they are copper hoses in diffrent colors but they are not cheap . but this will make it hard for them to do this and also will make them pretty much never need maintnace again other then the short rubber collors on both ends.
Old Jul 24, 2007 | 07:54 AM
wiz kidd's Avatar
have the system flushed really well, and make sure all the air comes out of it, getting air out of the system is sometimes hard, could be a clogged heater core causing it, could just be an air bubble.
Old Jul 25, 2007 | 04:29 PM
04 Intimidator's Avatar
I would go the flushing route as well. It costs more, but you don't want that system clogged up with corrosion.
Old Dec 18, 2008 | 06:20 AM
Thanks for the input. I found the problem. Despite the previous owner installing a new water pump, it was not OEM. The fins were bigger, thin aluminum and it was churning (beating)the coolant so hard it was cavitating and creating air bubbles despite continual bleeding of the system. Not knowing this, I took a chance and tried a new waterpump (OEM) and saw the difference when I got the old one off. Put on the OEM water pump, runs like a champ.
29-31 MPG highway with the 3.4L - outstanding and powerful besides. A cols air intake and I will be a happy camper.
Blazed SS
Jul 5, 2014 01:05 AM
ecosta221
Jul 4, 2013 01:17 PM
reaper18769
Sep 7, 2010 10:03 AM
scottwern184
Mar 23, 2010 01:42 AM
2003supersport
Mar 20, 2009 08:36 PM
