Head Gasket
Old Dec 17, 2008 | 10:32 PM
hawkfn52's Avatar
Default Head Gasket
I have a 1999 3.1 monte carlo I think my head gasket may be going bad are they easy to fix?
Old Dec 18, 2008 | 10:39 AM
SpaceAce's Avatar
Default RE: Head Gasket
hawkfn52,
Why do you suspect the head gasket?
I just did a breakdown to the heads (replaced one of them) on a 96 3.1 couple months ago. Ifyou are semi-talented in the art, this job takes a while but can be complished without too much trouble. First, make sure you have a breakdown manual to start with, it helps with torque and other misc spots. I replaced a lot in-addition to the head gasket just becauseI was into it, so that is something to think about also. There are a few tricky points that my manual did not mention and I found out the hard way, so if you get stuck just post up and we can walk you through it. One being the lower heater hose coupler (it pulls out via the tabs, can't really describe it, but you'll know what I mean when you get to it).
Good luck
New2MonteNY
Apr 25, 2017 01:59 PM
z34monte95
Jan 31, 2014 09:28 PM
jhartley
13
May 22, 2010 09:44 PM
redbug2
Oct 2, 2009 08:08 AM
prez
Jun 6, 2009 11:41 AM
