TURN SIGNALS
Old Jan 14, 2008 | 06:56 AM
willie8701's Avatar
Default TURN SIGNALS
WHERE IS THE TURN SIGNAL FLASHER LOCATED ON A 2001 MONTE MY SIGNALS GO OFF SOME TIMES THEN YOU HAVE TO HIT THE FLASHERS TO GET THEM TO WORK THANKS.
Old Jan 14, 2008 | 01:29 PM
04 Intimidator's Avatar
Default RE: TURN SIGNALS
Could you describe this a bit futher? I just can't picture it.
This might be a good boneyard thing to check on as well. Find the relay in your car manual and pull a used one to test.
Old Jan 14, 2008 | 01:32 PM
scc24540's Avatar
dan i think he means the relay, and if memory serves its on the passengers side behind the glovebox in that area
Old Jan 14, 2008 | 07:11 PM
mickey's Avatar
nope in our cars i belive it is under the hood in that fuse box on the right fender.
if not there it might be on the pass side same places as the Drivers side pannel just on the other side of the car.
Old Jan 14, 2008 | 09:20 PM
The Black Machine 29's Avatar
replace the hazard switch lol if you ever have it go off nail the hazard switch with your fist a couple times and watch it magically work again
Old Jan 14, 2008 | 11:15 PM
ORIGINAL: The Black Machine 29
I had to take the dash again to do this once myself when I was installing my head unit because I forgot to reconnect it so that could definately be an answer.
monteriderLS
Apr 1, 2013 08:57 AM
01whitess
Feb 18, 2013 08:55 PM
MELISSA
Aug 14, 2007 03:29 PM
InTheIROC
Jan 11, 2006 10:55 PM
