TURN SIGNALS
RE: TURN SIGNALS
According to my info, it is a combination turn signal and hazaed flasher, and is located on the firewall, just left of the steering wheel under the instrument panel. You need to remove the sound insulating panel from the bottom of the dash to get to it.
Wayne
http://www.cardomain.com/ride/2319272
Wayne
RE: TURN SIGNALS
thats usually where they are, when you stick your head up under the dash under the steering wheel its over towards the side of the car, kind of on the back half of the fuse panel....should just be a square block
monteriderLS
04-01-2013 09:57 AM
cmw239
09-12-2007 07:52 PM
