Info: Turn Signals
Old 05-29-2015, 08:01 AM
wkimes's Avatar
I think I am going to gamble with the cheaper fix. Might lose 25 bucks, but better then loosing over a hundered.
Old 05-29-2015, 09:21 AM
I had the SAME issues and I fixed it in 2 minutes when someone said it was probably a bad ground wire right above the headlight. wiggled it a bit and it came right off. Try moving it around and see if it's that before you spend money.
Old 05-29-2015, 12:03 PM
wkimes's Avatar
Is this the headlight on the drivers side or the passenger. I also just installed a K&N intake and had to hook somthng up to the main ground cable under the intake. I wonder if that could be the cause now that you mention it.
Old 05-29-2015, 05:32 PM
I have a 04 Monte, it was above the driver side headlight.
Old 06-03-2015, 01:13 PM
wkimes's Avatar
I have the same issue, just hit the hazards real quick and my turn signals work again lol
Well it happened again last night and I took your advice. I macked right on and right above the hazard switch and it started to work. Guess I will have to replace it when I get a chance. We will see how long the smacking works.
Old 06-03-2015, 07:29 PM
I'm going on 2 years now
monteriderLS
04-01-2013 08:57 AM
01whitess
02-18-2013 08:55 PM
MELISSA
08-14-2007 03:29 PM
InTheIROC
01-11-2006 10:55 PM
Quick Reply: Info: Turn Signals
