turn siginals
Old Jul 5, 2009 | 10:50 AM
dominic's Avatar
Default turn siginals
2002 montie 3.8
the turn siginals will not work all the time.so i went and changed the fuse. that did not seem to help.
what else should i look for.any suggestion at all.
dominic
Old Jul 5, 2009 | 11:12 AM
Enzo354's Avatar
STILL SLOW
Do they come on at all without blinking, or nothing at all?
Old Jul 5, 2009 | 11:26 AM
jibb3r's Avatar
Seems to be a very common issue in these cars.
Mine does the same thing. The turn signals work about 50% of the time. If I hit the hazard button on/off, they will work again. I've read the flasher is actually part of the hazard switch on the dash, which is what causes this issue. For now, I will toggle the hazard button on/off, until I have a valid reason to remove the whole dash panel.
Old Jul 5, 2009 | 11:28 AM
dominic's Avatar
they will come on and flash and work properly
then when i try to use the turn siginal again.nothing at all happens.they will not flash or turn on also i got to keep on hitting the turn siginal untll they start to work again.
could it be a relay switch?
dominic
Old Jul 5, 2009 | 11:33 AM
dominic's Avatar
hope i do not have to take the dash a part.
to fix this issue.it seems like i loose wire.two might be connected'what would
this cost to get this fixed
Old Jul 5, 2009 | 11:44 AM
jibb3r's Avatar
You don't have to take the dash "apart", literally. Just remove the whole "face" (not sure what else to call it, as I am no mechanic) of the dash, which goes from door to door. (If you look at your dash, the "face" of it, is all one piece, that holds your radio, vents, ignition, hazard switch and goes over the gauges and steering wheel) I've read it's only a few screws that hold it on, and the rest are clips.
I am just lazy, and will replace the flasher when I upgrade the radio. I've seen the flasher/hazard switch on eBay a few times for 20-30 dollars.
Old Jul 5, 2009 | 12:26 PM
dominic's Avatar
great
thought the dash would need to come out.
if i'am going to do that maybe i should upgrade the rado as you mentioned.
that is a releif that the dash does not have to come out
thanks for everyones help.
dominic
Old Oct 1, 2010 | 06:32 PM
Manny00SS's Avatar
I have a 2000 monte. Is the flasher behind the gauges and all that? I
01whitess
Feb 18, 2013 08:55 PM
04MonteLS
Jul 7, 2006 11:21 AM
trigger
Jun 12, 2006 04:05 AM
jayturk99
Feb 26, 2006 01:30 AM
InTheIROC
Jan 11, 2006 10:55 PM
