6th Gen ('00-'05): Tune Up Question
Old Mar 11, 2020 | 10:44 AM
Armahnii's Avatar
Default Tune Up Question
I have an 02 Monte and I知 more than positive that I need to do a tune up on this car. I was wondering if I need to replace the ignition coils and if so how many I do need. Forgive me if I sound stupid but I知 new to doing my own car work
Old Mar 11, 2020 | 12:32 PM
There are 3 coils, but they aren't typically a tune up item. If they test out ok and aren't visually damaged, they're probably fine to keep running.
Old Mar 11, 2020 | 01:18 PM
Armahnii's Avatar
Thanks. I wasn稚 sure since when I look it up, it always talk about replacing those too. Would the fact that I need a tune up cause my engine to misfire
Old Mar 11, 2020 | 02:08 PM
Misfire can be a number of things, I would do plugs and wires and maybe the upstream oxygen sensor. As those things are good to keep up on.
Old Mar 11, 2020 | 02:22 PM
Armahnii's Avatar
Okay I went to Autozone to get my CEL scanned after it randomly started to blink and I recurved the following codes:
  • P0446
  • P0141
  • P0446
  • P0141
  • P0302
Autozone told me that I needed to replace the Fuel Tank Pressure Sensor to fix the codes which didn稚 seem like that was correct but I could致e definitely been wrong
Old Mar 11, 2020 | 02:24 PM
Armahnii's Avatar
I致e recently replaced both the upstream and downstream sensors. However the codes had stayed for the longest for both of them. Then they disappeared now I have one back. I知 truly lost here with this car
Old Mar 11, 2020 | 03:44 PM
Check the wiring on the upstream sensor if you are still getting the P0141, or did you replace with a bosch? I believe bosch weren't very reliable with these engines.
P0446 can be anything in the EVAP system, hard to really tell without a smoke test or a visibly broke piece. Or even just need a new gas cap.
P0302 is your bank 2 misfire. Pull that plug and check it out, or move the plug and coil to a different one and see if the misfire code moves
Old Mar 20, 2020 | 11:26 AM
nitehawkjcb's Avatar
Great advice ChibiBlackSheep. Never rule out a failing MAF sensor also.
Old Mar 20, 2020 | 11:56 AM
Fyi, codes will stay stored and keep the CEL on until the code is cleared even after repair.
Old Mar 21, 2020 | 04:19 PM
Not entirely true. If you resolve the condition that caused the code, the car needs to re-process that diagnostic per the required parameters to de-activate the CEL. It might still retain it in history, but it will no longer be active, which means the light goes out. But obviously the quickest/easiest method is clear the codes and see if the light comes back on.
07ss_ls4
13
May 9, 2014 12:17 PM
Derekl21
Nov 26, 2012 08:28 AM
S.O.G.
Nov 26, 2012 12:38 AM
my00monte
17
Aug 20, 2011 07:36 PM
