trunk latch
Old May 24, 2010 | 02:30 AM
02montecarlo's Avatar
Default trunk latch
Hey I have a 02 ss n I can't pop the trunk via either the inside button or from the remote. Whenever I push either one a horrible noise occurs n the latxh doesn't open. I can only access it with my key..any ideas?
Old May 24, 2010 | 09:04 AM
Get a new trunk latch, or try some WD-40 when you open the trunk and see if that one is just dirty.
Old May 24, 2010 | 11:19 AM
Maybe, check the fuse, but I doubt it. Worth a try??
Old May 24, 2010 | 11:39 AM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
Make sure the two screws that hold the latch there are secure, cuz when I first got mine, one was broke and I had a hard time closing and opening mine. If that doesnt happen or help, I would get a new latch it sounds like the inside of the latch may be shot.
Old May 24, 2010 | 01:03 PM
Well I put wwd40 on the latch n even with the trunk open the noise still occurs when I press the remote open button. Could it be the latch solinoid?
Old May 25, 2010 | 01:02 AM
Sliver's Avatar
Latch solenoid could be stripped. I had a lincoln mark VIII and when I would lock the doors the passenger side would make a terrible whirring noise. The solenoid was stripped out and could not engage properly.
Old May 25, 2010 | 01:06 AM
Ok thank you...wonder how much those run
jimsmonte80
Apr 22, 2015 10:04 PM
dhart99
Dec 12, 2011 04:04 PM
Joe Bloggs
Nov 10, 2009 07:51 AM
mrl390
Dec 17, 2007 05:30 PM
ddschneider1972
Nov 20, 2007 06:55 AM
