5th Gen ('95-'99): Tranmission quits shifting after heating up!
Old Apr 16, 2019 | 11:37 PM
Serg Ni's Avatar
Default Tranmission quits shifting after heating up!
Hey. I had this weird ordeal the other day where I temporarily got stranded.
I was going up a huge hill and the transmission would slowly get out of gear and into neutral. After I beat the hill and was on the other side, the transmission must have gotten really hard and I couldn't get into gear at all. I pulled onto the side of the road and waited. After 10 minutes I got back into gear, but after 5 more minutes of driving it got hot again and went into neutral.
I don't know how or why it's doing this and there are no trouble codes. Well I got an fuel cap code but it went away.
Old Apr 17, 2019 | 08:02 AM
Could be low on fluid or it could be a trans fluid pressure issue which could be caused by a bad solenoid.
Hows the fluid itself look? Pink, dark red, or brown?
Old Apr 17, 2019 | 02:07 PM
nitehawkjcb's Avatar
Hopefully it's just low on fluid... Otherwise there's a good possibility a rebuild is needed..
Old Apr 17, 2019 | 03:58 PM
Wink
Something to check
I have changed mine in an around 35 to 50K as a rule. I have one vehicle that you cant even check the fluid level in the thing is sealed so you have to have a Garage change it out in that case they recommended 100K it had 104K when I finally changed it out. Mostly cause of my travels. it had the same actions as you have described. Changed it out and it works fine now.
RasCricket
Jan 16, 2014 03:19 PM
ndaguanno
15
Dec 22, 2012 01:51 PM
shamgodlou
Sep 21, 2010 11:23 AM
bearbear3_4
Aug 13, 2009 11:50 PM
aussiek2000
Jun 19, 2009 09:32 PM
