6th Gen ('00-'05): traction control lights/abs light on
Old Jun 20, 2019 | 11:34 AM
bobsmontess's Avatar
Unhappy traction control lights/abs light on
hello everyone I have a 04 monte carlo ss supercharged now I have the abs/traction control off light on and it says service traction system , I replaced both front hubs still have lights I then replaced both back hubs still have problem I unbloted the abs pump ground wire and cleaned the connection still have problem , I traced wires of traction control and inspected them , besides being filled with dry dirt when I opened plactic wire covering the wires look ok I got a reading of around 4.5 to 4,8 ohms of resistance from testing wire ( is that good ?) I did have 4 codes on abs c1248DRP disabled ,c1225frt excessive left wheel speed senor variation c1232 open or short frt left ,c1233 open or short frt right speed circuit I cleared them and still have 3 only one that is gone is c1225 all the others are still there please help I am at a loss to what it could be
Old Jun 29, 2019 | 11:57 PM
JamesCallie's Avatar
Default Speed sensor
It's the speed sensor in the hub bearing that triggers the lights. You have to change the harness.
bobsmontess
Jun 30, 2019 03:53 PM
claydoh
Oct 1, 2016 12:08 AM
Storman1
Aug 22, 2015 08:54 AM
Watty
Feb 2, 2015 03:37 PM
terr
Jun 4, 2014 06:09 AM
