Info: abs/traction control issues
Old Sep 27, 2016 | 11:38 PM
claydoh's Avatar
Default abs/traction control issues
sigh! I am still having abs and traction control issues,posted this here a while back. its fine for a while then it goes nuts on me,right now every time I get in the car I get a hum...hummm then the abs light comes on then the traction control light, once they come on they stay on and the problem generally goes away? sometimes the brake pedal will vibrate and become sketchy on braking! I have replaced the front hubs,both c/v axles,checked the speed sensors. I don't have the cash for a abs obd scan tool. anybody else had this issue? the hum gets me, does it without touching any pedal or anything!! this is driving me bananas!! thanks peeps!!
Old Sep 28, 2016 | 09:51 AM
The rear hubs also have ABS. Have you checked those wiring / hubs? It's not always just the fronts that are the issue.
Also follow the wires up to the engine, check the grounds.
Old Sep 29, 2016 | 07:38 PM
coolhand's Avatar
It could be a broken wire in the harness going to one of the wheels. I bought a cheap code scanner on ebay that also would check the abs system, and found it was the front right wheel that was my problem. I fixed the break in the wire and never had another problem with it.
Old Oct 1, 2016 | 12:08 AM
claydoh's Avatar
thanks guys I will check this out!!
