Traction Control?
Old Mar 4, 2009 | 07:10 PM
mavrickf1613's Avatar
Monte Of The Month -- January 2009
Default Traction Control?
On my 06 monte the service light is on for the traction control, How do you service this your self or what does a mechanic do to correct this issue?
Old Mar 4, 2009 | 07:23 PM
RickAKATed10's Avatar
Photobucket
Default RE: Traction Control?
If you are under warranty take it to the dealer so they can scan it. I would say take it to AutoZone, but they do not scan for anything but Engine check lights. I am sorry I can not be any more help.
Old Mar 4, 2009 | 08:29 PM
Is traction control under the powertrain warranty? because my basic warranty is out
Old Mar 5, 2009 | 08:25 AM
are they the same as the previous generation, all in the hubs?
or maybe you just have a sensor that went bad, causing the trip up
Old Mar 5, 2009 | 05:33 PM
red03ssmonte's Avatar
nope its not under powertrain warranty, well mine wasnt. To fix mine it was the traction control module or some **** like that, thats what the shop told me. They fixed that then told me that there was some kinda valve on the abs that was out that tripped it to.
Old Mar 5, 2009 | 08:46 PM
Cowboy6622's Avatar
you don't need traction control... this is a FWD, if you can't pull the car out of a slide with the throttle and the steering wheel, the traction control won't save it either.
hopefully i don't crash after saying you don't need it now!!
it's probably just a sensor somewhere. i'd think if it was the piece in the hubs or wherever (i don't have a clue how the mechanics of traction control work), i'd think it wouldn't throw a sensor on the computer.
Old Mar 5, 2009 | 09:19 PM
bonang's Avatar
My 07 had to have the wheel bearing replaced to resolve the same issue. I currently have 67500KMS on mine (yes im form Canada lol)
So far I had to replace:
Wheel Bearing
Steering shaft
Ball Joint
Rear and front link kits(drivers side)
couple tire presure sensors
So your issue is a bearing and will have to be diag'd by a GM tech or a repair shop that can scan the CANbuss sys in your car.
Old Mar 5, 2009 | 09:20 PM
bonang's Avatar
Oh its the ABS sensor that controls the TCS.
Old Mar 5, 2009 | 10:19 PM
yea in all honesty after gettin mine fixed ide say screw traction control I turn mine off anyways, I forgot about it the other day at work (we have a curvy parking lot) tryed doin a little power slide out of it and the damn traction control light came on and the car pulled hard to the left (Iwas going left lol) so it pulled harder than what I was doing idk didnt like it so ur not missin out all that much with out it
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
Jul 8, 2012 08:27 AM
willysmith
Mar 16, 2006 07:50 PM
Bob50th
Jan 7, 2006 09:46 AM
