traction % abs lights on
Old Aug 17, 2007 | 06:54 PM
catdaddy10's Avatar
Default traction % abs lights on
I have 2000 Monte Carlo that the traction light,the abs light came on when i stopped.checked brake pads. what do i check now and how to fix problem.
Old Aug 17, 2007 | 08:17 PM
HyperFox's Avatar
Default RE: traction % abs lights on
Check the ABS sensors.. T/c gathers its information from the abs sensors. Inspect all connectors around the hubs. Id reccomend a good slathering of di-electric grease. If that fails, you will need to jack up the vehicle and spin the hubs slowly, use a multimeter and check across the leads for resistance. The one that is constantly open or closed may be it, or the one that gives an oddball reading.
Not 100% sure.. but good luck.
Old Aug 17, 2007 | 08:52 PM
04 Intimidator's Avatar
I have that myself one in awhile. I think I have a defective one somewhere too. It happens about once every 4-5 months or so. I've been lucky to be able to turn the car off and back on and clears itself.
mwmarshall
May 14, 2022 02:43 AM
2004SS
Dec 17, 2021 06:08 PM
Chris s
Jan 27, 2013 04:30 PM
Pure2sin
17
Dec 15, 2009 10:38 PM
Ds 01 MC
Aug 20, 2008 05:58 PM
