TPMS Maintenance
Old Feb 26, 2011 | 12:37 PM
Thumbs up TPMS Maintenance
TPMS Maintenance
Pat Goss
All cars now have tire pressure monitoring systems. Well, don't think of that as being a replacement for your tire gauge because it really isn't. See, if you want the absolute best life out of your tires and the best fuel economy and everything, at least once a month, get out the trusty old gauge and check the pressure manually. That will give you the optimum pressure, not just a safe pressure, which is what the tire pressure monitoring system does.
Next, you have to be proactive in selecting the people that work on your car, they're going to take the tires, remove them or install them. You have to make sure they know how to do it, and they have the proper equipment, because if you don't do it right, the bead of the tire will come up across the sensor, and it breaks the sensor. Hundred and fifty bucks gone right there. Here we have one where they did that to it. Right here, the whole end of the sensor is gone. It also has another common problem. The end of the stem is gone; it has actually remained in the cap due to corrosion. So just loosening it with your fingers, it just falls apart.
Alright, that corrosion also extends to the inside on many of these. It can damage the electronics in the sensor itself. Now where does the moisture come from? The moisture comes from air compressors. So you might want to consider nitrogen in your tires because it is absolutely dry, and it will prevent most of these problems.
Now, next thing, don't bump a curb because if you bump a curb, you can wind up damaging the stem. At the same time it can crack the sensor. And corrosion problems, if you want to prevent them, dialectic silicone grease. Take a little bit of it put it on each one of the threaded portions of the stems. Make sure you always have a good cap on the stem that will help keep moisture out.
Also when you go to the repair shop, they should have one of these tools. This is the tool that releases air from the tire without taking the core out of the valve stem. Very important, saves a lot of problems.
Old Feb 26, 2011 | 12:39 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Good write up space! Necessary information there.
Old Feb 26, 2011 | 12:44 PM
Thanks Sgt Miller, but I am only the messenger : )
The article is from
Pat Goss of MotorWeek, I watch their program on Public Broadcast TV and he has some great basic tips.
Goss' Garage
Pat Goss helps consumers understand car problems and how to speak the same language as their technician. Effective communication with a repair shop is vital to keeping consumer and operating costs under control.
http://www.mpt.org/motorweek/autobasics.shtml
Source link above...EnJoy
Old Feb 26, 2011 | 02:05 PM
hmmm, I asked this question here a couple times in the past about nitrogen and now I have a good answer. thanks Space
Old Feb 27, 2011 | 11:19 AM
Justin Knight's Avatar
Default I hate the babysitting systems
I know technology is great and all but I like to check my own pressures, and a good driver should feel a difference if a tire goes low. i know i do.
I like cars that i have to physically drive not just push buttons and let the car do the rest. parallel parking systems should be outlawed, back up sensors should be banned, tire pressure monitors are for the lazy, and i know gps is a great thing but what happened to just using our brains and remembering or paying enough attention to know exit 144 is your next turn off the highway
sorry for the rant.
Old Feb 28, 2011 | 11:22 AM
RickAKATed10's Avatar
Photobucket
I hate the TPMS system on our cars.
Old Mar 4, 2011 | 05:38 PM
Phobos's Avatar
I have never actually had a good reading from my tpms. I think there may have been one time it went off. I guess its a good thing i have always only put nitrogen in my tires. However, the last time i went to have them filled the company either forgot to put one of my wheel nut covers (for lack of a better term) on or didnt tighten it and now its gone.
Old Mar 4, 2011 | 06:20 PM
LuSe4's Avatar
Is there anyone other than me that thinks Pat Goss is a smug bastard? I'm just sayin!
jasonmcr
Jul 31, 2009 09:52 AM
bigmichaelcool
Dec 10, 2008 08:40 PM
snakeking194
Jul 7, 2008 03:54 PM
jasonmcr
Feb 29, 2008 06:28 PM
Chucks88SS
Dec 13, 2007 09:40 PM
