Top swap PCM tuning.
Old Sep 19, 2010 | 11:57 PM
Pure2sin's Avatar
Default Top swap PCM tuning.
I just want to know if anyone has had any issues with tuning a top swapped PCM on a 00-02 PCM (L36)? I saw a thread on another site that got me concerned about the use of a 2 bar MAP and tranny problems with the PCM flash.
Old Sep 20, 2010 | 01:50 AM
montecarlo01ss's Avatar
yes dont flash a gtp bin file onto the monte pcm
Old Sep 20, 2010 | 03:04 AM
Pure2sin's Avatar
Than what bin file would you use? I heard that you can't use the 2004 bin file on a 00-02 because of transmission issues?
Old May 25, 2025 | 10:57 AM
Chillest_Fern's Avatar
any info on bins to use?
Old May 25, 2025 | 05:41 PM
Henderson21's Avatar
What are you looking to accomplish? Have you swapped your top end?
I can probably supply some stock .bin files for you. But you'll need your own .bin to modify as well.
What software are you using?
Old May 25, 2025 | 08:56 PM
So I swapped in an L67 entirely, only thing that is stock 01 monte is the left motor mount and coil bracket.
I want to use a L67 os on an 01 monte carlo. I have my L36 os’s ve tables tuned to the air fuel spark from a L67 but just looking to see if theres a l67 os that’s useable.
I ran a 2000 park ave ultra, then a 2001 and 2002 gtp bin and got dtc codes. I have a 2004 monte bin witten on one of my pcms that I put on the car with a crank relearn code, but wanted to see if theres new info about if the bin will work correctly with the transmission or not.
I used LS droid to OS swap, TinyTuner for OS tuning, then Hp Tuners for quick and easy tuning.
I use a OBDXPRO VX then a MPVI3
Old May 25, 2025 | 10:18 PM
Did you drop in the beef up version of 4t65e as well? Or is the trans still stock from 01?
Old May 26, 2025 | 01:20 AM
Stock sprockets and chain, hardened output shaft and 4th clutch hub, with a shift kit and hd 3.29 diff. The transmission was from a 2003 lesabre so I had the swap valve body, a couple sensors, internal harness, then replaced the fluid pump. So a 01 conversion basically.
Old May 26, 2025 | 04:56 PM
I think your transmission is the deciding factor here.
Unless you'd be willing to rewire the harness for the trans I think your stuck with L36 OS.
I dont know of anyone who modified the l67 .bin enough to run the older trans.
Steveg
Jun 16, 2017 06:11 PM
cellman26
May 15, 2017 09:24 PM
James O'Conor
Jul 3, 2012 07:56 PM
MONTE48
Jul 4, 2010 01:09 AM
Cowboy6622
Aug 4, 2007 10:26 PM
