TIGHTEN GAS CAP
Old Sep 17, 2006 | 11:55 PM
heatherd's Avatar
Default TIGHTEN GAS CAP
Now after I have fixed all my issues with my new car I get a TIGHTEN GAS CAP message in the message center. Of course I got out and tightened it, shut the car down restarted it etc. I have now gone through 4 full tanks of gas and run almost to E without running out and the message continues to come on. Any suggestions?
Old Sep 18, 2006 | 07:33 PM
InTheIROC's Avatar
Default RE: TIGHTEN GAS CAP
Either the evaporative emissions system has a leak in it (could be a bad gas cap or a number of vacuum lines), the diagnostic pump is bad, or it hasn't re-run it's diagnostic check on the evap system to determine if there is a leak. It may also be a software problem, if GM is using software. I'm not sure what the requirements are for it to run the test, but I would think it would have run sometime within the last four tankfulls of gas.
Sean_G
Aug 9, 2013 01:50 PM
MJClemm
Feb 2, 2013 09:16 AM
77gp
Oct 12, 2012 04:27 AM
Jul 5, 2010 02:20 PM
jay26
Jul 15, 2007 04:59 PM
