Thumping in Rear Tire. What could it be?
Old Jan 24, 2012 | 02:58 PM
TSauer09's Avatar
Default Thumping in Rear Tire. What could it be?
When I start to accelerate my rear driver side tires starts to make a thumping noise, increasing as I speed up. Once I get to a certain speed (Approx. 35mph or so) the noise goes away. But, when I get to around 65mph or so it starts to thump a lot and has a little shake to it. I'm curious as to what the problem may be. Any help would be greatly appreciated it.
I'm a college student and I'm needing it fixed ASAP because I have to travel to clinical sites all over the state and going 60mph on the interstate isn't going to cut it.
Thanks.
Old Jan 24, 2012 | 03:25 PM
Can you rotate the tires and see if the sound moves with them?
One of your weights for balancing might have fallen off, also check tire pressures.
Old Jan 24, 2012 | 03:31 PM
TSauer09's Avatar
Thanks. I heard that and I've also heard a belt may be off track? Hopefully it isn't too big of a pain to fix.
Old Jan 24, 2012 | 03:34 PM
Budsjlm's Avatar
Flat spot in tire,
somthing stuck in tire(usually associated with loosing air)
lost a wheel weight
belts in tire seperated
bobwags
Aug 4, 2015 08:21 PM
MonteLSV6
Aug 22, 2013 01:39 PM
monteguy03
May 11, 2012 06:53 PM
jibb3r
Jan 14, 2010 05:28 PM
tripph
Jul 5, 2009 02:53 PM
