Think i screwed up need help!!!
Old Feb 5, 2013 | 09:37 PM
ruthilldude's Avatar
Default Think i screwed up need help!!!
l just finished replacing my ac compressor. When I went start car turned key and nothing happened no clicking or anything. My instrument lights started flashing security and service traction controll service engine soon and the trac light on dash is on. I had the battery disconnected while I was working on it. I had to remove airbox to remove fans I removed the electrical modules from airbox. When I hooked up battery and tried to start and got nothing I realized I had not plugged the modules back up in airbox. Did I cause my issue? I have read were other folks have had this issue. This the first time it has happened to me but I have onlyhad the car 6weeks. Please help me get it started!! Thanks
Old Feb 5, 2013 | 10:24 PM
If I were to take a guess, the car needs to undergo a simple security re-learn process. One source for the security re-learn is on the additional items tab here:
ZZPerformance - ZZP 1.0 PCM #ZZ-380010PCM
Or search MCF, as it's been posted a bunch of times. Give that a try and hopefully all is good (make sure the battery has a full charge too when you do this).
Old Feb 5, 2013 | 11:11 PM
When I have the key in the on position the it flashes the security light then low fuel light the service engine soon over and over. I will try the relearn thing tomorrow. Thanks
Old Feb 6, 2013 | 09:35 AM
Went out this after letting the car set with the battery disconnected over night and took out PCM and blew it out with air and put it back n and the car started right up. Happy Happy Happy
supaschupp88monteSS
May 1, 2013 12:22 AM
03SSLE
Dec 28, 2012 07:46 AM
Mr Grizzly Mint
Mar 31, 2012 11:28 PM
StrongTakeover
Mar 5, 2012 01:11 PM
