4th Gen ('81-'88): Temp Gauge help
Old May 11, 2015 | 04:01 PM
DerrtyD's Avatar
Default Temp Gauge help
So for the most part my gauges are okay(speedo is kinda wobbly and the tach is wobbly too) but my temp gauge is the only one NOT working. i see where its suppose to connect on the drivers side of the engine under the manifold but i dont see the so called green wire with the clip that connects to it. my computer is out so that might be why the wire is missing.
1)how can i hard wire it, most of my gauges are but the mechanic i had disappeared off the face of the earth
2) can the wire be bought at the store
3)can i tighten my gauge needles up or not
thank yoouuuu
Old May 11, 2015 | 04:21 PM
thank yoouuuu
If your speedo is wobbly, check the connection at the transmission. make sure it is tight. If it continues, you may need a new driven gear or speedo cable.
Your tach is attached at the distributor and if it is wobbly, check the connection at the distributor..it is attached on one of the little prongs underneath where the starter attaches.
When I get home I will take a pic of all three of these areas for you.
But all of my gauges except speedo are aftermarket. Not sure if you can get just a temp sensor without the gauge.
Is your temp gauge aftermarket or stock?
Old May 11, 2015 | 05:27 PM
Default Connections
Connection at transmission for speedo
Connection on distributor for tach
Connection on block for temp gauge (aftermarket)
File Type: jpg
File Type: jpg
File Type: jpg
cjbrooks91671
May 21, 2014 02:27 PM
bigdomvegas
Mar 19, 2013 12:16 AM
pizzacarlo
Nov 8, 2010 10:55 PM
smolek37k
Dec 1, 2007 07:08 PM
01whitess
Dec 20, 2005 03:29 PM
