Tail lights - Running Lights
Old Nov 27, 2011 | 04:49 PM
TKG2000's Avatar
Default Tail lights - Running Lights
It seems some of the newer (not sure what year it started) MCs have rear running lights that use both top and bottom lights like I have always wanted instead of just the bottom lights.
Is there a conversion - wiring adapter to make my 2002 SS do this?
Insight, help or pointers to previous posts on this would be much appreciated.
Thanks!
Tim
Old Nov 27, 2011 | 08:26 PM
Heres a thread about it, its fairly easy to do just need a 3 wire plug & modify it to fit in the socket
https://montecarloforum.com/forum/pa...ilights-26671/
Old Nov 28, 2011 | 12:40 AM
Mike are yours still working fine?
Old Nov 28, 2011 | 11:22 AM
Yup still working good & i love the way they look
Old Nov 28, 2011 | 12:06 PM
TKG2000's Avatar
Default Tailight Rewire - post pointer - Thanks!
Awesome! Many thanks!
Tim
Old Nov 28, 2011 | 01:02 PM
Or you can use that as a good excuse to swap to the LED tails
Old Nov 28, 2011 | 01:11 PM
But this way is cheaper mike
Old Nov 28, 2011 | 02:03 PM
Jester_20's Avatar
are the 7th gen tails the ones that are on all the time?
(i'd go look, but i'm workin and will forget to check when i get off )
ctownbandit
18
Oct 13, 2018 04:49 PM
01LS Goin Bad
Oct 28, 2011 12:48 AM
RickAKATed10
Jan 23, 2009 10:38 AM
espo83
Sep 12, 2008 10:00 PM
