Switched Wire
Old Apr 4, 2008 | 11:57 AM
God_Bot's Avatar
Default Switched Wire
Has anyone found a switched wire in these '06-'07 Montes?
It appears that the reason my underglow is no longer functioning right is because I had wired the remote lead to a constant on and that causes the controller to boycott me.
I also currently have my subs hooked up to a toggle switch, and I'll be mounting a rocker switch in the dash or center counsel this summer for it. If no one knows of a wire that I can use as a lead I may just have to do the same for my underglow.
I just got an email from the people that I had ordered a Hayne's manual from, something about a factory mixup and all, but it's in the mail now, I may just have to wait and see if that has any information.
Old Apr 4, 2008 | 02:07 PM
Default RE: Switched Wire
Hi `Garrett,
You can call `Eddie below for help, `if you don't want to wait : )
He should be able to `help, they are the pro's : )
"Nothing Ventured ~ Nothing Gained" [8D]
Eddie Sr.
NU5K
I want you to be happy!
Call or
email me with
ANYPROBLEMS
or questions
713-626-7627
Old Apr 4, 2008 | 11:56 PM
josh405's Avatar
Sup bro I'm guessing your looking for a wire that is only hot when you turn the key. If this is the case than you can hook up your lights the same way I did my interior led light strips. By the way mine is an 06 just like yours. What you need to do is open up the fuse panel in the passenger floorboard and tap into the RAP fuse and run your wire from there so then you lights come on when you turn the key and will stay on like you factory radio when you turn the car off until you open the door. By the way that fuse panel is easyer to access if you take the door sil trim panel off. Hope this helped That fuse is a 10amp and it is all the way at the top kinda by itself.
Old Apr 5, 2008 | 12:42 AM
God_Bot's Avatar
Okay thanks Josh, I'll have to check that out next time I'm back home with some tools. Dad and I had checked them the first time, maybe we just missed it.
Old Apr 5, 2008 | 07:38 PM
josh405's Avatar
Ya its the only fuse that is not hot all the time,only when you turn the key. And its all the way at the top of the fuse panel box kinda resessed in a little bit above the relays
Nuffy
Dec 5, 2009 07:10 PM
TTT_Travis
14
Oct 7, 2009 10:37 PM
RickCoMatic
Oct 21, 2008 10:25 AM
RickCoMatic
Oct 1, 2008 01:36 PM
RickCoMatic
May 11, 2008 10:24 PM
