6th Gen ('00-'05): Supercharger belt tensioner installation?
When I did my nightmare of a installation for my battery & started her up I noticed my supercharger belt tensioner was bouncing(the one under the coil packs). Its making a rattle noise I thought was coming from the supercharger, verified the location with a long screwdriver to the ear. I have removed the belts before, but never removed a tensioner.
What tools are required?/ what socket do I use to remove it? Anything special I need to do to take it off? Torque specs?
I plan on doing this in the next week or so, its been making the rattle for about 2 weeks now.
It's been a while.
But if that bolt doesn't remove it, there is a smaller nut/bolt in the middle of the tensioner that should. Not sure of the size, but probably a 10mm or 13mm
No I definitely saw the date, I was curious so I searched on here and found this without an answer. So I decided to make an answer so if anyone else does what I just did they would have the answer lol. were all good!!!!
24_48Fan
03-21-2007 10:01 AM
