strange beep
Old May 17, 2010 | 08:41 PM
My stupid low tire pressure sensor went on (in the information center) in my 05. I checked all the pressure in the tires and every thing was fine. Then I went through the radio to reset the tire pressure setting. It went away and never came back.
Old May 17, 2010 | 08:49 PM
Do you know anything about this light switch thing?? I just dont know what its all about?
Old May 17, 2010 | 08:57 PM
Nope sorry - I usually don't even use the manual headlight switch.
Old May 17, 2010 | 09:34 PM
Justin Knight's Avatar
Okay i'm a tech and i deal with the dumbest oil/tire resets ever they are all crap.
on 6th gen mc's/impala's the radio is the preferred way of reseting the tire/oil monitors. GM made the headlight switch in and out 3 times to park lamp position and off to reset the tire monitor and gas pedal three times to the floor when the key is in the run position. the reason they did that is simple
1. they used old technology that was easier to incorporate to new systems by just adding to the system than redesigning it completely.
2. did it so people could still reset warning systems if they put in an aftermarket deck.
hope that adds clarity to the situation, as an example a newer honda is as follows key on, puch trip button and hold for 10 seconds, once oil life % starts to flash release button for no more than 3 seconds, push and hold button a further 5 seconds or until 100% is shown.....WTF are those wacky japs up to???? don't even ask about volvo's.
Old May 17, 2010 | 10:12 PM
Okay yeah that clears it up for me, but it didnt turn off the tire light (low psi). Maybe I did it wrong or somthing?? Thanks though. Guess you were right Brock
Old May 17, 2010 | 10:17 PM
whoa the low tire light was on already? make sure the tires are cool from sitting, not hot from right off the highway. put 35 psi min depending on tires (ignore tire pressure label on car) and reset the TPMS. if the light is still on you have some other issue or its not reseting some how.
Old May 17, 2010 | 10:26 PM
No no, I let the air out after brock said it was for the tire monitor, and waited for the light to come on.
Old May 17, 2010 | 10:28 PM
Enzo354's Avatar
STILL SLOW
Off subject but I like the green headlights lol
Old May 17, 2010 | 10:49 PM
Dale3goodwrench's Avatar
Monte Of The Month -- March 2009
I have an aftermarker HU in my car. I reset the low air pressure light by turning parking lights off and on 3 times. Im sure that is the beep you are hearing.
Old May 17, 2010 | 10:51 PM
You like the green headlights huh, you should see teh brights, they turn that really bright blue almost white.
