Opinion Needed: Starting problem
Old Nov 24, 2018 | 06:55 PM
Big Perat's Avatar
Default Starting problem
I bought a brand new battery. I don't drive the car daily. After sitting for about a week, the car doesn't start. What can this be? And I have checked the alternator.
Old Nov 24, 2018 | 08:27 PM
What year Monte?
I assume the car needs to be jumped, then it runs fine as long as you drive it daily?
Sounds like a parasitic drain. Typically most people begin with "do you have any aftermarket electronics, like lights, radios, speaker amps". Sometimes if those are not wired in properly, they end up staying on and draining the battery.
I can also tell you from experience, it can be the alternator. My '04 had a parasitic drain that took a long time to find because it was only driven once in a while during summers only. I pulled the alt and had it benched tested numerous times at multiple locations. Only ONE test attempt failed, re-tested on the same bench and it passed. Had it also tested once or twice on the vehicle. I finally replaced it when it began putting off a smell of burning electronics (and I had multiple people near the car notice the smell). After I changed it, no more problems.
There is test equipment to help you find a parasitic drain, I don't have that available to me.
Old Nov 25, 2018 | 11:39 AM
Turbo Rick's Avatar
A simple 12vdc test light can help you find what’s drawing. Disconnect the positive battery cable and put the test light between the cable and battery. If it lights up, something is drawing power. You can pull fuses 1 by 1. The test light will shut off when you pull the fuse on the circuit that’s drawing power.
8car2002
Feb 13, 2020 08:48 AM
plokm24
Jul 26, 2016 02:51 PM
supaschupp88monteSS
May 1, 2013 12:22 AM
RonBGA
Nov 20, 2012 09:14 AM
Danariel
Mar 6, 2011 08:42 AM
