Starter 2007 monte carlo ss 5.3 L
Old Sep 29, 2013 | 11:56 AM
Hognutsdeluxe's Avatar
Default Starter 2007 monte carlo ss 5.3 L
I have removed the 2 bolts from my starter, but the starter seems to be welded, glued whatever, to the engine, how do you remove a stuck starter.
Old Sep 29, 2013 | 12:06 PM
Sorry to read that you are having problems with your starter...First,
I'm not a tech & hopefully one of our expert tech member's will post some advice...
Below is a link you can check out while you wait for one of our tech member's to post. Good Luck
| Repair Guides | Starting System | Starter | AutoZone.com
Click above link
Old Sep 29, 2013 | 12:22 PM
Found the below in my file search and I don't know `if it will help or not, but it may be worth a read > Good Luck & Don't 4-get to check back on your thread.
s there a trick to remove the starter in a 5.3l. I replaced the transmission and the starter was very hard to take out and now i cant get it back in. Any suggestions?
Category: Chevy
Monte Carlo
the only way to make it any easier to make sure that the transmission cover plate is loose before removing/installing the starter. It has a tendancy to get hung up on it. ALso make sure that the starter does not seem warped in any way.
[/COLOR]
Old Sep 30, 2013 | 06:26 AM
Category: Chevy
Monte Carlo
[/COLOR]
Thanks for that, But I did manage to get the starter out, and it turns out that it was good. My next step is to find out where the neutral safety switch is located, can anybody help me there?
Old Sep 30, 2013 | 07:47 AM
03SSLE's Avatar
A lot of the time a starter will test good on the bench, but once put under load will not turn the engine over. If at all possible it's best to test it on the engine using a remote starter switch.
IIRC there is a switch under the console that (because of bad routing) the wiring becomes frayed/broken and prevents the vehicle from starting.
rmorman
Oct 24, 2013 06:32 PM
ladybridgeport
Mar 22, 2012 01:05 AM
kellwhy66
Sep 25, 2009 09:29 PM
MrCheesefood
Dec 10, 2008 04:50 PM
makonkey
Jun 12, 2008 11:12 AM
