2nd Gen ('73-'77): Engine VIN where to find question?
Old 07-29-2018, 01:53 PM
18thletter's Avatar
Default Engine VIN where to find question?
I pulled the alternator but don't see it. Got 3 numbers off the back behind flywheel 3999289 and then GM or CM 10T and H2472. Only the 3999289 shows any search engine results. Any help on the important number I'm looking for?
Old 07-29-2018, 07:57 PM
Here's a link that might help you Chevy Small Block V8 Casting Numbers - Mortec Number location is on back of engine behind drivers head. it also shows in link. Good luck
Old 07-31-2018, 05:03 AM
18thletter's Avatar
thanks man, appreciate that. I'm looking for a stamped number with letters and numbers that was supposed to be on the block behind alternator.
Old 08-08-2018, 07:36 AM
18thletter's Avatar
Default 1 last question
Found the number buried under grease. Where can I verify or confirm the number as original?
Old 08-08-2018, 07:15 PM
That link I posted tells you about that number on page 2 That one is on the passenger side in front of the head right ? The casting numer is located behind the drivers head.This is a 6 digit number no letters and is raised (cast) into the block not stamped like the one shown .Good luck
Old 08-08-2018, 10:01 PM
18thletter's Avatar
Old 08-09-2018, 04:40 AM
H 24 72 should decode too August 24th 1972 production date That 3999289 should come up on a search apparently not in this link . Still should be able to reference that number though maybe someone else has another casting link .After a little watching for you , is this a big block 454 ?
Old 08-09-2018, 07:34 AM
18thletter's Avatar
That it is! I did find the 399' number doing a Google search but nothing on the other so again appreciate the info. I'm guessing it's only worth something to someone restoring a 73 Monte who wants all the numbers to match or I've watched 1 too many Barrett Jackson auctions lol
Old 08-09-2018, 07:53 AM
Well it's still a pre 1973 block which would still be worth something. 1972 was the last year for real power before emissions kicked in effect and big blocks lost a few hundred horse's
Melssj5
12-05-2017 01:35 PM
Bushwhacker
04-24-2014 06:47 PM
lunchboxor
01-27-2012 11:01 PM
UMAGA
11-29-2010 08:43 PM
SuperMonte8
01-20-2010 05:25 PM
Quick Reply: 2nd Gen ('73-'77): Engine VIN where to find question?
