2nd Gen ('73-'77): Engine VIN where to find question?
I pulled the alternator but don't see it. Got 3 numbers off the back behind flywheel 3999289 and then GM or CM 10T and H2472. Only the 3999289 shows any search engine results. Any help on the important number I'm looking for?
Here's a link that might help you Chevy Small Block V8 Casting Numbers - Mortec Number location is on back of engine behind drivers head. it also shows in link. Good luck
That link I posted tells you about that number on page 2 That one is on the passenger side in front of the head right ? The casting numer is located behind the drivers head.This is a 6 digit number no letters and is raised (cast) into the block not stamped like the one shown .Good luck
H 24 72 should decode too August 24th 1972 production date That 3999289 should come up on a search apparently not in this link . Still should be able to reference that number though maybe someone else has another casting link .After a little watching for you , is this a big block 454 ?
3rd Gen ('78-'80): Identifying Engine
Melssj5
Dec 5, 2017 01:35 PM
lunchboxor
Jan 27, 2012 11:01 PM
