squealing noise from front left suspension when turning right
Old Sep 16, 2014 | 08:08 AM
bower1992's Avatar
Default squealing noise from front left suspension when turning right
I have a 2003 monte carlo ss with 126,000 miles on it and within the last week I've noticed a couple times that when you your the wheel about 3/4 of the way to the right it makes a squealing noise from somewhere around the front left tire. Almost sounds as if I was doing a burnout but it sounds really faint. I know a little bit about cars but I'm definitely no expert and correct me if I'm wrong but could this be a bad strut? What makes me wonder is there is this horrible rattle when going over even slight bumps and the front end of the car bounces more then it should. Any help would be appreciated thanks
Old Sep 16, 2014 | 08:23 AM
Welcome to the MCF
Check out the below link & hopefully it will help...
* Use our MCF Search Engine above to help with your problem(s)..
Also check back to see what our Expert Tech Member's post (?) Good Luck
Old Sep 16, 2014 | 10:23 AM
l67ss's Avatar
could be a wheel bearing
ymhajoe
May 16, 2014 10:29 AM
Monte'99
Oct 20, 2012 10:53 PM
tictacxo
Sep 16, 2012 09:47 AM
zk6216
Mar 8, 2008 05:34 PM
ralphtrent
Oct 27, 2006 07:13 PM
