Squeaking noise when driving slow
Old May 28, 2011 | 09:40 PM
jimbo7's Avatar
Default Squeaking noise when driving slow
My 04 is making a squeak-squeak noise when driving slow up to about 25mph (at least noticeable up to that speed). When I touch the brakes it stops. It does it when turning too. Sounds like it's coming from right side and it's fairly loud too. I'm thinking it's a wheel bearing. Any ideas?
After reading past posts, someone suggested a belt or a pulley bearing. Don't think it's that cus it doesn't change with engine speed. Although my belt is squeaky when cold.
Old May 29, 2011 | 08:17 AM
Is your ABS light on ? Could be you brakes, or wheel bearing.. Jack front end up and check wheel bearing play ..
Old May 29, 2011 | 08:55 AM
jimbo7's Avatar
no light and no codes. i'm gonna rotate tires tomorrow, so i'll check it then.
Old May 30, 2011 | 03:13 PM
DerEin's Avatar
Wouldn't surprise me if it were just one of your rear brake pads.
Wheel bearing will typically make more of a grinding sound.
04MonteLS
Feb 21, 2011 11:53 PM
joedaslik
Nov 14, 2009 02:46 PM
echoingvoid
Sep 20, 2009 01:08 AM
menaja19
18
Dec 6, 2007 10:43 PM
gtpfastboy
Nov 1, 2006 05:14 AM
