Random kill/shutoff
Old May 30, 2011 | 09:40 AM
DRuben's Avatar
Default Random kill/shutoff
This morning I got up and started my car with no problems and went to the store 30 minutes away. After I came out I tried to start my car it started up for like 1 second then violently shut off.?. Then it started back like normal. This problem occurs atleast once every 2 weeks. Also, is it normal for my Monte to start up fast? Its like 1 second after I turn the key its running.
Old May 30, 2011 | 11:37 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Whoa!!!
Same thing happened to me a couple days ago!!!
Except I was driving tho, out of nowhere my car shuts off as if I turned the ignition to switch it off, no hesitation, nothing, just shuts off
I pull over to the side of the road and i Turn it back on, it starts up and runs just fine
Hasn't done it anymore tho, hope it doesn't do it again either
Old May 30, 2011 | 12:04 PM
DRuben's Avatar
That is dangerous and I hope that doesnt happen to you again. I was completely shocked when it started happening because It always runs great except for this. A couple of months ago it did use to violently shake for like 7 seconds when I started it up after 10 minutes of it sitting but it seemed to have went away and this problem has surfaced. Spark plugs and wires are good, I get my oil changed every 3k miles, I just dont know what that could be...
Old May 30, 2011 | 01:24 PM
nitehawkjcb's Avatar
Sounds like either the ICM or crank sensor is acting up
Old May 30, 2011 | 03:29 PM
PacerSS's Avatar
Check your main grounds. Specifically the one on the bell housing bolt. And your battery cable connections. A mean bump or hard turn identified this for me once.
85v6
Feb 24, 2015 04:41 AM
Enzo354
Mar 9, 2009 06:15 PM
couch
Mar 14, 2008 12:15 AM
06MCLTZ
Nov 1, 2007 07:04 PM
romanc_monte
Jun 14, 2005 04:09 AM
