speedo problems need help bad???
Old May 1, 2007 | 06:31 PM
derrel96ls's Avatar
Default speedo problems need help bad???
there is a cable that connects the speedo and the tranny to tell my mph, and i cant seem to find the wire that connects to the tranny. My speedometer doesnt seem to work unless i get on it hard. Every onther gauge seems to work besides the speedometer and the odometer. I just got a speeding ticket because i didnt really know how fast i was going and the pig thought i was being a smart ***. so 96 dollars later i still cant seem to fix my speedo. Anyone got the solution on how to fix it???
Old May 1, 2007 | 09:08 PM
2000LS's Avatar
Default RE: speedo problems need help bad???
well i'm not positive, but i belive the speed sensor is on the rear of the trans near the right side output shaft. and ive also heard that if you have something going out in yer trans or it has higher mileage you can lose signal because its also a magnet. if theres a bit of play in there might be why it works when u get on it hard. anyways if it was mine i'd try to locate it, remove, clean, reinstall, and try it out.
Old May 2, 2007 | 01:45 AM
derrel96ls's Avatar
thanx i tried that and i works great now, so thanx for the advise
Old May 2, 2007 | 07:54 PM
04 Intimidator's Avatar
ORIGINAL: 2000LS
Good call!!! Not to many one l post fixes. =D
Old May 2, 2007 | 08:08 PM
derrel96ls's Avatar
all it took was some bubble gum anda band aid to fix it.....oh oh dont forget the paperclip. But its diffently fixed i had it to 112 until it cut down.....damn governor
Old May 2, 2007 | 09:30 PM
2000LS's Avatar
hey cool, glad to know i'm not always wrong.
on the downside though theres probly alot of crap floating around in your trans to of done this.
Old May 3, 2007 | 12:32 AM
derrel96ls's Avatar
yeah probably, but this may sound bad but im trying to break it so itll give me a reason to get a new engine and tranny lol
TMoney
Apr 9, 2014 09:32 AM
Camaro Drew
Jul 19, 2012 09:34 PM
BigPana
27
Jun 24, 2011 11:37 AM
GreyMonte
Oct 10, 2006 06:08 PM
jac1599
Sep 22, 2006 01:58 PM
