6th Gen ('00-'05): Sometimes dim gear selector lights on cluster
Old Apr 14, 2013 | 12:37 PM
rickc1177's Avatar
Exclamation Sometimes dim gear selector lights on cluster
Ok here's my problem. The gear selector lights on the instrument cluster where the mileage is, they are dim during the day and slightly visible at night. Now other times they are completely visible with no problems. Would this be bad bulbs or the dimmer switch?
Old Apr 14, 2013 | 12:45 PM
lilmonteZ34's Avatar
Experiment with the dimmer switch. If it dims again, manually turn the dimmer to the brightest setting.
Old Apr 14, 2013 | 01:09 PM
nyislanders's Avatar
I have that too, it's probably a loose connection somewhere. Honestly, I fixed it by hitting the cluster lightly a few times and it comes back to full brightness. :P
Old Jul 6, 2015 | 01:05 PM
soleinova's Avatar
Default Same issue
Hi,
I know this threat is a little old but I am having this same issue with my 01 SS, the "PRND321" LCD display gets dim and after a little hit comes back. But now the full cluster lighting works random. Whenever I hit the lens the LCD will come up to full brightness but the tach lights go off. Some other times everything works except the tach and some other times everything works as it should. Any suggestions?
Note, I previously removed the cluster 2 months ago to replace the cluster lens because I broke it when hitting the lens to make the LCD bright up but everything was working perfectly, I just started noticing this intermittent failure about 2 weeks ago.
Old Jul 6, 2015 | 01:26 PM
It almost sounds like something may be loose. I would go back and recheck your connections
Old Jul 6, 2015 | 03:23 PM
soleinova's Avatar
I will give it a try to the connectors later today, hope this fix it.
Thanks!
el pachuco
Feb 21, 2015 09:11 PM
turbo monte
Apr 4, 2013 10:01 AM
SilverRiff
Jun 29, 2010 07:21 PM
Yellow_Monte
Feb 14, 2008 09:28 AM
erik2282
Oct 1, 2005 03:15 PM
