Transmission gear selector broken?
Old Jun 29, 2010 | 07:21 PM
SilverRiff's Avatar
Default Transmission gear selector broken?
Ok this is one of if not the biggest issue I have found with my newly aquired 1987 Monte LS. The column shifter does not seem to be attached to the orange gear selector "arrow" in the dash, so I cannot tell what gear I am in. The arrow will jump slightly when shifting, but never gets out of the park position. Also the shifting through gears feels pretty loose/sensitive. Like I have to be careful when shifting as not to overshoot the gear I want...hope that makes sense. Where do I start in fixing this problem? I assume there is some sort of cable running from the steering column to the dash. Are these symptoms of 2 different issues, or are they related by some linkage? Any help would be great, because this is annoying!
rickc1177
Jul 6, 2015 03:23 PM
turbo monte
Apr 4, 2013 10:01 AM
MrRobertLee
Feb 27, 2011 05:25 PM
casper
Apr 19, 2009 08:26 AM
erik2282
Oct 1, 2005 03:15 PM
