4th Gen ('81-'88): Sloppy gear shift selector (column)
Old Aug 10, 2018 | 07:27 PM
tcline85's Avatar
Default Sloppy gear shift selector (column)
Hello all, I have a 1985 Monte Carlo with a TH350 3 speed trans P R N D 2 1 the gear selector is on the steering column. Currently there is a lot of play in the selector lever. Is there anyway to tighten that up or when I take it apart should I be looking for something that might be worn or broken? I haven't pulled it apart yet, would like some advice before I get started. Thank you.
Old Aug 11, 2018 | 08:06 AM
Jeffs02rwdSS's Avatar
There are plastic/nylon bushing on the shifter linkage that do wear out over time. Should be located under the car where the two shifter linkage rods connect together. Also should be on the steering colum under the hood where the linkage connects. There is also a bolt that you can loosen and make some minor adjustments. near the transmission right next to one of the bushings. Good luck
justinb628
Oct 22, 2019 06:29 PM
JamesH831
Oct 22, 2016 07:49 AM
SilverRiff
Jun 29, 2010 07:21 PM
Monte SSV
Jun 2, 2009 05:42 AM
Moffer
Jul 17, 2005 12:28 AM
