Scraping noise when I turn the wheels
Old Nov 12, 2009 | 02:55 AM
Darius Lovehall's Avatar
Default Scraping noise when I turn the wheels
When I turn the car, I hear a scraping noise that sounds like its coming from the front right-side wheel. When I'm driving on the road straight, I don't hear the noise. Any ideas on what this could be?
Thanks
Old Nov 12, 2009 | 08:39 AM
Are you turning left to hear that noise?
Could be a wheel bearing / hub assembly starting to go bad.
Old Nov 12, 2009 | 10:11 PM
Yes, I hear it when I turn left. I'm thinking that this is something that I could replace myself?
Old Nov 16, 2009 | 10:07 AM
If it is the wheel hub / bearings:
http://www.paulstravelpictures.com/G...ent/index.html
Old Nov 18, 2009 | 10:58 PM
Default Replace both front hub assemblies?
Thanks for the guide.
Should I replace both front hub assemblies? I hear the noise from the right side when I turn left.
Old Nov 19, 2009 | 08:22 AM
If you only hear the noise when turning left then it's only the right assembly.
Old Nov 19, 2009 | 12:48 PM
sonin66's Avatar
since your at it, you might want to just replace both
Old Nov 19, 2009 | 01:07 PM
I would replace as needed, it's not like he'll have the other side of the car taken apart and it will be easier to do. He'll have to start from Step 1, so might as well wait for it to go bad (if it does) I've only replaced 2, one in the front and one in the rear. If I did both at a time, it would have cost me double and it hasn't even been a problem yet.
Bizzyyall
Nov 3, 2014 06:45 PM
Slugger088
Mar 16, 2011 07:40 AM
johnniep
Nov 26, 2010 10:30 PM
saigashooter
Mar 18, 2010 10:25 PM
Jomao_o
Dec 18, 2009 04:52 PM
