Replacing PCV on 2005 3.4
Old Jun 26, 2008 | 03:47 PM
2005ls's Avatar
Default Replacing PCV on 2005 3.4
What is the trick to replacing the PCV valve on a 2005 3.4? It has some kind of metal bracket holding it in, therefore I can not remove it. Looks like my only option is to cut the bracket, but that doesn't sound like how it was to be designed.
Thanks in advance.
Old Jun 27, 2008 | 11:07 PM
montecarlomike81's Avatar
Default RE: Replacing PCV on 2005 3.4
You should be able to pull the pcv from the valve cover without messing with the bracket. Although, be sure not to bend the plastic tube that the pcv is connected to.
montejass
FWD Tech Guides '95-'07
15
Jan 28, 2013 06:18 PM
jay26
May 28, 2008 08:04 PM
george13
May 3, 2008 10:29 PM
jayturk99
Jun 21, 2007 07:39 AM
brvancamp
Dec 13, 2004 11:35 AM
