pcv
Old Apr 28, 2008 | 03:37 PM
george13's Avatar
Default pcv
can some one tell me exactly where its located on a 01 monte
Old Apr 28, 2008 | 05:34 PM
kweef's Avatar
Default RE: pcv
are you wanting to know where the valve is?
Old Apr 28, 2008 | 06:05 PM
rysZ34's Avatar
Default RE: pcv
3400 or 3800 motor?
Old Apr 28, 2008 | 07:00 PM
kweef's Avatar
Default RE: pcv
wow, i completely forgot about that, im feelin pretty dumb 2day
Old Apr 29, 2008 | 09:15 AM
rysZ34's Avatar
Default RE: pcv
It's okay Jeremy, we all have our moments. ;o)
Old May 3, 2008 | 10:29 PM
purewhitemonte's Avatar
Default RE: pcv
When you view the engine from the front - for the 3800, the PCV valve is in front of the alternator. For the 3.1 or 3.4 (3400), it's located just to the right of the oil filler cap. Either one should a little metal can with a black plastic arm coming out of it hooked to rubber vacuum line. When you pull it out of the engine crankcase and shake it, you should hear it clinking and free enough to do it. If no sound, you have a clogged PVC valve and needs to be replaced. Should be a $2-3 dollars to replace. It gets clogged due to the recircualting of exhaust fumes and oil and from the crankcase.I make it a rule to change every other oil change - just to make sure it never has a chance to clog.[sm=smiley10.gif] When it does clog, the engine will have trouble idling and will make the engine die after warmup.
montejass
FWD Tech Guides '95-'07
15
Jan 28, 2013 06:18 PM
sickofsoyo
Jul 13, 2008 03:44 PM
jay26
May 28, 2008 08:04 PM
jayturk99
Jun 21, 2007 07:39 AM
brvancamp
Dec 13, 2004 11:35 AM
