PCV
Old Jun 20, 2007 | 03:35 PM
jayturk99's Avatar
Default PCV
The diagram under the hood is not any help. Where is the PCV located? 2005 MC LS. Trying to improve gas mileage, any other suggestions?
Old Jun 20, 2007 | 06:36 PM
wiz kidd's Avatar
Default RE: PCV
not 100% sure what is, haven't changed mine, but you could do fuel filter, plugs and wires, and an air filter to improve gas milage
Old Jun 20, 2007 | 08:49 PM
2000LS's Avatar
Default RE: PCV
the pcv is in the front valve cover , to the drivers side of the oil fill cap.
Old Jun 21, 2007 | 12:42 AM
04 Intimidator's Avatar
Default RE: PCV
Switch to K&N air filter. Never need to buy a new one, plus it allows easier air flow. Easier air flow = less work the engine needs to do to suck in air.
Old Jun 21, 2007 | 07:39 AM
wiz kidd's Avatar
Default RE: PCV
you should run some seafoam through it too, that stuff really helps out and cleans up all buildup through the system
montejass
FWD Tech Guides '95-'07
15
Jan 28, 2013 06:18 PM
sickofsoyo
Jul 13, 2008 03:44 PM
jay26
May 28, 2008 08:04 PM
george13
May 3, 2008 10:29 PM
brvancamp
Dec 13, 2004 11:35 AM
