replacement key
Old Jan 4, 2014 | 12:24 PM
Latasha's Avatar
Default replacement key
I need to know how i get a new ignition key for my 98 z34 and how much will it cost me do i order it specially or can i get it in a store its the kind that has the VATS chip in it and mine is broken and need a new one very badly i never got a spare when i bought it
Old Jan 4, 2014 | 01:09 PM
Latasha:
I would recommend 1 of 3 ways to resolve your key issue...
1) Call a Locksmith
2) Contact your local Dealership
3) Check at a local scrap yard /pullapart..
Unless you are or have someone that's mechanically inclined.... I would recommend contacting a locksmith or a dealer... However, As an owner of a 1999 Z-34 Monte Carlo ...Most dealerships no longer carry parts for our Model Years...
So, I would then recommend calling a locksmith.
I honestly have no idea how much it would run..
Old Jan 4, 2014 | 02:51 PM
If you just need the key, most dealers can still make keys for cars beyond 10+ years. If you don't have the original key available, they will require some proof of ownership before cutting a new key (I know someone who went through this a while ago on an old Caddy).
Now, I am not sure if the keys for your car are chipped or not. GM has a few different anti-theft systems in their cars and not all of them require a chipped key. Odds are if you can provide your VIN to a dealer, they could let you know if it's chipped or not.
Remember, phone calls are free. Give a local dealer and a locksmith a call and I'm sure you can get all the info you need.
Old Jan 4, 2014 | 03:43 PM
Jason:
Its chipped like my 1999.
Old Jan 5, 2014 | 02:24 PM
Latasha's Avatar
ok thankyou I have another ? with that chip in my key being broke can it cause it to shut my fuel pump down
Old Jan 5, 2014 | 09:06 PM
The chip is a security part of the key. It's to prevent someone from simply brute forcing the key lock and starting the car with a screw driver.
I'm not sure how the passlock system works on pre-2000 GM cars, but on the 2000+ cars, it prevents the injectors from firing.
Old Jan 6, 2014 | 09:22 AM
nitehawkjcb's Avatar
I don't think it would be related to the pump. It would prevent the car from cranking though.
Furder2010
Oct 22, 2017 06:49 PM
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
big green dog
Oct 20, 2005 04:25 AM
03SSdriver
Sep 16, 2005 10:43 AM
