rear seat
Old Jan 9, 2011 | 10:04 AM
peno67's Avatar
Default rear seat
I had recently tore the interior out of my 07 for a sound deadening project. After reinstalling the aft lower seat I notice the RH side though locked down has some vertical movement and is fairly easy to pull back out. I haven't quite figured out the plastic lock mechanism. The odd thing is that the other side locks nice and tight after a swift smack on the top of the seat.
Any ideas?
Old Jan 9, 2011 | 12:04 PM
Is there a little black piece on the bottom of the seat to lock it in? I lost mine and they wouldn't stay down
Old Jan 9, 2011 | 03:37 PM
peno67's Avatar
yep, plastic piece still attached to the square metal piece.
Old Jan 9, 2011 | 04:59 PM
There should be a hook type thing under the seat and that should go right into the black piece, I would check the black piece to see if maybe it was damaged
Old Jan 9, 2011 | 07:49 PM
peno67's Avatar
I suspect that is the case. Nothing noticeable though I am thinking maybe being plastic it has been deformed.
Old Feb 5, 2011 | 10:06 AM
Jester_20's Avatar
did you have any trouble getting the rear seat itself out? I've taken the seat out of my 02 a million times and it appears to be the same mechanism for the 06 but when I try to pull it out it feels like it's locked into place. Any suggestions?
BenTheFox150
Jul 26, 2011 12:32 PM
eviling
Jul 23, 2010 04:29 PM
red04montels
Jul 4, 2010 07:22 AM
gothkid
May 7, 2009 02:59 PM
fastback4
Dec 21, 2008 06:39 PM
